Apps Issue with designing for Multiple Screen Android
pb_lead26
Eclipse has provided us with different qualifiers like size, ratio , etc. So when I select a qualifier, it provides us with the right emulator screen to make our layout. But are these emulators screen loaded under the right layout folder? I dont understand, how Nexus 10 which is a xlarge screen size is loaded when I load the activity_main under the Normal layout folder?
am I blindly arranging these layouts? Because before this, I had arranged all layouts perfectly and when I went to run it on a Virtual Device, it looked a complete mess. I looked at the xml files and they were completely in the wrong places.
I have used qualifiers like : normal-long, normal-notlong, large-long, large-notlong, small-long, small-notlong, xlarge-long, xlarge-notlong,
Should I change the qualifiers? Please suggest.
Hey pb_lead26, welcome to our AndroidForums!
I've moved your thread over here to our Application Development area where you'll find the best help and advice.
Cheers!
