Help Issue with Nexus 5
Amine1987
Hello
I bought a nexus 5 in february and i have an issue with it. Sometimes i loose the normal network for 30-45 seconds. Ive changed once my micro sim card but the problem still remains. I'm from Quebec province in Canada with Bell as a provider....
Could you suggest me somthing to solve this problem
Thanks
Same problem here in the UK
I lose internet connection and sometimes call signal as well
Last few days for 10 minutes or so
I have an R in the signal bar which I assume means I'm roaming
You might want to check and make sure that your APN settings are properly set for your carrier.
Also in your APN settings try changing your "MVNO Type" to IMSI
I'll sometimes drop signal for a few seconds but its likely because Sprint is doing a lot of tower work in the area. Try making sure your phone is set up correctly on the network. Toggling airplane mode might help alleviate the issue as well.
If it is indeed a radio bug and not carrier issues there isnt much you can do, except hope the next update fixes them.
Are you guys running stock only?
Are you rooted or running a custom ROM/kernel?
I know that the earlier builds, pre 4.4.2 had a radio bug that would drop signal.... But were supposed to have been fixed in 4.4.2. Although I've heard users have had issues on this build too.
As Rxpert83 said, Toggling airplane mode should help too as this will reset/refresh the radio. Although this would probably be only a temporary fix.... Same with rebooting the device and then the problem reoccurs.
You could also try going into "settings/more/mobile networks/preferred network type and change the setting to LTE (which is recommended) or to 3g. If your in an area that doesn't have LTE then 3g would be the preferred network setting... Or try setting it to "Global"
I did read that quite a few users specifically on Canadian - Bell/Rogers/Fido and users in the UK have had this problem and that by changing the "MVNO type" in the APN setting to "IMSI" solved the issue for them.
If your rooted and have made a proper nandroid and an EFS backup, you could try flashing a different radio/modem version. This post has a "Modems Link" to the various radio versions for the N5 and is an good thread about EFS and how to back it up.
[MODEM] [EFS] Nexus 5 Flashable Modems and E
I never had this problem at all until I just did a factory reset on my phone and now it's happening all the time. At least in my case it seems like it's wi-fi related. If I have wi-fi off I have a solid LTE connection all the time. If I'm on a shoddy wifi connection, though, I'll lose data and my cell connection completely. Airplane mode doesn't help, only a full reboot. And then the problem can possibly just happen again immediately after rebooting.
As far as my phone setup goes, I have all the same stuff installed as before the reset. Less, actually. Other than that, the only thing that changed was me doing a factory reset of my phone, hoping my battery life would be better. Little did I know it would make my phone near unusable.
There is a bug in 4.4.2 where some people lose cell connection for a few seconds at a time. This happens to me a few times a day, thankfully it had never lasted longer than a few seconds (if i'm in an area i know has signal.)
If you "lose cell connection" does that mean a few seconds of not being able to hear the other person or does it drop the call and you have to call back?
I dont know if I've ever had it happen during the call, but have only noticed it when looking at my status bar the signal indicator will show no signal for a number of seconds and then jump back onto the strong signal.
That has happened to me a couple of times on a call it just drops and I call back or they call me back but the good thing is its only been a couple of times n it wasn't important phone calls
