drdeceased
My roommate and I both have Incredibles.
Hers has had the OTA and is running 2.2.
Mine was rooted yesterday and is running stock 2.1.
Last night she complained of her internet being broken.
I took a look and found that her mobile network stated 'turning on' but just stuck in this grayed out state.
I attempted to disable it buy turning on wifi.
Which did not work.
I turned on airplane mode which did work.
Then with the 3g radio off I got wifi enabled.
Her mobile broadband will not connect...
And if the status is correct it will not even turn on the radio properly.
All the while my stock 2.1 has no issues.
Odd occurrence....... figured it would fix itself by morning and went to bed.
I wake up and now my phone is doing the exact same thing
Anyone with similar issues?
Which did not work.
