Help Issues with apps & wrong time
MBM7881
Ok I have a weird issue with my apps (tweetcaster, fb, babyesp). They all seem to have the wrong time. For example if I post a comment or post a pic etc on fb the time will be wrong. It will say it was posted an hour ago even though its only been a few minutes. Same thing with tweetcaster and babyesp. Any ideas? TIA
Not sure if there s an option in the settings (haven't looked, sorry), but individual Apps - depending on what they do - do have time settings. One of them is "Use local time".
When I select that option, then the clock on the home Page, SMS etc shows an hour fast. e.g. 11.10 instead of 10.10.
I am in the UK by the way with daylight saving, so that may explain it for me.
Might be of some help to you.
Your time zone is incorrect. You set it up for GMT and not London/ Dublin and GMT does not change for summer.
