at the moment, when i try to boot the phone i'm getting the pic with the phone and the computer with the little yellow triangle in the middle. every once and a while i can get it to the download screen, but when i do, and i try to open odin, odin wont see the phone. if i disconnect and reconnect it will see the phone, but i cant download anything.
is there an update.zip i can load onto the sd card that i can use to have it boot correctly without getting the pic of the phone and computer?
or some way i can get odin to see my phone so i can load CWM recovery?
any help would be greatly appreciated.
thanks
ok well after going nuts for a while, i figured it out, to get into downloading i was holding down the vol-down while hitting power with the usb plugged in. then i read that you are supposed to start with the phone off, hold down vol-down and insert usb.... bingo!
/sigh
thanks
/sigh
