kramericaman
I'm on my 3rd Motorola Droid in one week and all three are having the same issues syncing the pop3 accounts. Note that one device came from the store, and two were shipped so most likely not from the same batch.
Setting up the Pop3 accounts is time consuming, but not difficult at all. You have to make sure you enter the info exactly as it is set with each of your pop3 accounts or it won't pull from it.
Here are the problems I'm having:
1) Regardless of setting it to auto sync and using the minimum push time of five minutes, the device is not syncing automatically or consistently. One trick i learned is that if you actually uncheck auto sync and back out and then go back in and re-check auto sync it will start to auto sync correctly. You can also do the same with the email notifications by changing it, backing out, and then going back in and changing it to notify you. However, none of these tricks make a permanent correction to the sync. After a couple of hours you then have to do it manually.
2) The notifications that pop up in the green circles indicating the total messages in your "combined inbox" and the green circles next to each of your accounts indicating the number of new messages in each one DO NOT ADD UP PROPERLY. e.g. "comibined inbox" will say 10 messages (in the green circle), yet in account #1 the green circle will have a 3, and account #2 nothing, and account #3 will show 1 and account #4 nothing. This doesn't add up to the 10 it shows in the green circle next to "combined inbox".
3) NOTE that in the above issue accounts #2 and #4 showed no emails next to it. When I turn the device horizontally the green circles then show up next to accounts #2 and #4, yet it still doesn't display the accurate number of new messages.
Every time I call the techs are completely baffled by this and have no explanation. The only thing they can say is that they forward each complaint on to the "Motorola Droid Tech Team" and they will include it in their updates. We'll see if they fix this issue.
Aside from this the email works very well and the overall device works great.
