Very disappointed with update, at first all seemed OK then after 2 or 3 days it started to go wrong. The phone started to slow down, opening the camera would take about 30 seconds and taking a picture would take as long as opening it, scrolling through the gallery,the apps and even between each of the home pages takes so long you give up on it. Then it started to loose connection to the network no Internet or calls, I'm on the 3 network in the UK, I have to either turn off mobile connection or if that doesn't work switch it off and reboot it is all very frustrating. After the reboot it will appear normal for a short period, Any ideas anyone??????????????
