Issues with uninstalling kies mini from programs.
noetics
So i am trying to upgrade my phone from ecclair to ginger bread. I downloaded kies and installed the program. Then I was asked to install drivers by enabling USB debugging and connecting my phone to the computer and it would do it automatically. So after I finished that, I went to open kies and accidentally open the file that installs kies again. So what the file did was uninstall all of the mini kies stuff. So now I cannot install mini kies because it says that it is still installed. But i cannot get mini kies off my computer so that i may re-install. I have tried using CC cleaner. PLEASE HELP
Uninstall all the Kies program before trying the mini kies (un)install again. Kies supersede mini Kies.
Use the Control Panel Add/remove software to do so and reboot the pc after its done. Then you can try installing the softwares back.
