Root issues with UNREVOKED root
ok so I downloaded the driver at first I did it wrong so I had to start over. When I restarted the root it goes through the "pushing H-boot" etc and then restarts my phone. the icon for unrevoked (grey box) now says waiting for reboot... well ive been waiting for that reboot for about 10minutes now :/
Please help. :o
do you ahve HTC sync? if so uninstall it
ok stand by
if it asks me to install SYNC tell it no?
ok i have now uninstalled sync,when I try to run the reflash it says "waiting for device, plug in phone (it is already) and enable USB debugging (which is already enabled)
I'm having trouble installing the drivers, I keep getting android phone instead of Android 1.0 in the device manager
plz help! Just removed htc sync too
ok stand by
to both close and run it again
done it three times now...and still stuck at the waiting for phone message
ok showing a little bit of headway...I restarted my phone then reran the reflash...still no dice tho, reflash said it lost communication to the phone...
Uninstall HTC sync, and htc sync driver from control panel. Delete all previous usb driver folders you may have downloaded from previous attemps. Power up and plug in your phone. Open device manager and uninstall the driver for whatever you see (ADB interface, bootloader, etc. -- whatever shows up. Click the checkmark for removing the drivers software files if applicable). Unplug your phone, and plug it back in. Yellow exclamation point? If no then repeat uninstalling the driver. Do this as many times as it takes until the phone is plugged in, you get the driver software failed to install windows error message, and there is a yellow exclamation point in device manager. Then Reboot your phone into recovery mode. Repeat the process here. Once done, reboot phone normally, install the hboot drivers from unrevoked 3.0, start the .exe.
and you have installed the drivers and uninstalled pda net and htc sync? and enabled usb debugging?
never had pda net installed on my phone..usb has been enabled since I bought the phone and checking now...yes sync is uninstalled
my last post it takes me to the clockworkmod (green and black screen) with nandroid/etc before it loses communication
ok i did it...same thing...clockworkrecovery/losses communication
Still no dice.
Driver installed, htc and pda net uninstalled.
I am still getting the green/black screen and communications failed.
Tried both usb ports.
one more try then beddie-bye.
Still no dice.
exact issues that i am having
Try it on a different computer. One you haven't tried to root on.
I can't get Titanium Backup to work. Says I'm not rooted even though I am.
ill be able to try that a little later
