Help Issues:(
Hello, i have had my G5 for almost a year now and when i first bought it on 2.1 the battery wasnt the best, but it would last a full day, but now ive updated to 2.2 ages ago and ive noticed how bad the battery has got- its dying in under an hour which is obviously a very big issue.
Also i left it on charge over night and when i woke up this morning and checked it, it was on 19% battery when i checked before i slept and it was on 90%- confused!
Also i have to play around with my charger alot for it to actually work- whilst my usb cable will work with no issues- has my charger been damaged or broke?
The phone keeps doing a random vibrate in a specific pattern- this happens quite reguarly and has done since i updated to 2.2- i have tried factory reseting but that hasnt done nothing, the pattern is similiar to vibrate, few seconds gap, vibrate vibrate, its very annoying.
When i flashed my phone to CM7 and MadTeams Better 2.2 i did not have the vibrating issue- i have flashed it back to stock now.
Also when i close an app or come out of a menu my home screen applications and widgets often disappear for about 15 seconds which is very frustrating.
My phone is on stock 2.2 Froyo- Rooted with Universal Androot.
Thank you very much!
Curtis.
Curtis.
crazy stuff happening with your G5, i have owned mine for 8months and the battery has always been quite awful but your sounds like its pretty dead. i think replacing the battery will possibly be your own option on that issue.
The problem with the rom also sounds quite odd. im currently using a mad team cm7 2.3.5 rom atm but used a non madteam 2.2 which i found to be fine and had no issues as you described. i would say to keep your eyes out on this new cm7 2.3 rom and wait until it becomes more stable for daily use in the near future and some of you problems hopefully wold be resolved.
Good luck.
