Hopefully the guy can fix it
If it does get fixed, what new GUI should I put on it with Clockwork? I'm tired of Gingerbread.
Thanks
I'm tired of the gingerbread/froyo interface. They're the same thing, only the notification area has changed.
I want a new GUI. I was referring to CWM because that is used to update the phone to a new gui right?
I'm not sure what is out there for ROMs for your device, but a simpler and safer way to change the user interface is with a custom launcher (ADW, Launcher Pro, etc.) I used ADW for a long time and it had some nice features.
