Itouch ....Bluetooth .....why wont you pair AND connect?
bcrtj457
Seriously. Why can't I get these 2 to pair and connect. Both are showing up on each others devices but no where does it say for them to connect. How do I do this? Thanks.
Sent from my PC36100 using Tapatalk
What are trying to connect them to do? I do not believe the iPod touch is capable of any data (as in wireless tether or files) over it's Bluetooth.
I believe the main purpose of Bluetooth, and the only things it can do is A2DP for audio over BT and some kind of connection with a Nike Accessory.
Not sure if this is data or not but the ipod touches play games over bluetooth. Just thought I should mention that if it helps anything.
I do not do much gaming. I can't answer that one with 100% confidence. Although my hunch is that you will not be able to connect the Evo and the Touch.
Nothing to do with any limitations on the Evo, more to do with the limitations of the Touch.
