colchiro
Extreme Android User
[RELEASE][ALPHA][Discussion] CyanogenMod team Touchpad port
Alpha 2.1:
If updating from Alpha1, just grab the updated installer and you cm7 files and flash as usual.
For new install, you'll need all 4 files below.
Lots of stuff fixed: Issues - cmtouchpad - Android port for HP Touchpad - Google Project Hosting
DOWNLOADS:
ACME Installer/instructions, CM7, CWR, gApps, moboot (see above link for files)
Make sure to copy the gApps to your TP with the other 2 install files or you won't have Market!
To preserver battery stats, consider charging to 100% before installing.
CM7 progress update - BT and netflix. - YouTube
PROBLEMS/Solutions:
No Market: You forgot to install Google Apps (gApps)
Can't boot into recovery: You didn't install moboot
Rom Manager won't boot me into recovery... no option for Tenderloin: Use power menu... choose "reboot", then choose recovery
Need to reflash something?
Copy zip files (gApps, mootboot, etc)to cminstall folder ("cminstall" might be case sensitive).
Reboot and hold vol-up button down to boot into usb mode.
Redo: novacom boot mem:// < ACMEInstaller
