Its the same phone
I would have to respectively disagree with almost everything you have said. I think the blur widgets are fine, they might not be the prettiest but they function well enough, I literately have no lag, unlock screen is fine, the only widget I must have is Beautiful Widgets, just because I loved the HTC Sense Weather Widget.
I do agree that the stock dialer pad is missing t9, that sucks. There is an app that gives it, but I personally do not use it.
I use the stock home launcher and I seriously do not see any lag, the X has been every bit as fast as my Incredible was. Maybe you have something slowing down your phone? Maybe I am just incredibly lucky and got a better phone? I don't know, just wanted to let people know not everyone's phone is slow.
No issues with the Droid 2 here...
You need to download numerous apps and or widgets to make the x function correctly.
Perhaps "function correctly" is the critical factor as what each individual might consider to be functioning correctly could differ. And isn't this the goal of Android, to have an environment where apps can be created and downloaded so that people can customize their phones to have it function the way they want? So if what you are saying is that you have to download a bunch of apps and widgets to make it work the way you want it to but that you can do this, then isn't that pretty much the goal?
