Help itunes on Atrix
Jp77
Member
How do I get songs from my itunes onto my atrix without burning the songs to cd, ripping them to pc, then dragging onto atrix? Any suggestions?
I have an HTC Inspire, and not the Atrix, but they both run on Android 2.2, so it's probably the same.
I would recommend downloading the iSyncr app ($2.99), and using that. It made the process so much easier on my Inspire. It even comes with a (relatively brief) tutorial that walks you through how to upload the songs from iTunes.
Good luck!
You can also try the free version of doubletwist. The desktop app will automatically find the songs in your itunes library and you simply plug up your phone and sync.
I second Doubletwist (free). Works just like iTunes for your Android...select playlists and everything. No need to pay for anything.
You dont need any of that or at least I didnt. I just put 405 songs on my atrix today, when you download songs from limewire or bearshare or wherever it is you download them they go to a file on the computer. Mine was at documents>frostwire>shared. I plugged up the atrix and set it for mass storage on the phone setting. Then I just went to my file on my computer where all my songs were and dragged them into my atrix folder freemusicdownloads>music. They all just synced right up, no problems at all.
