Help iTunes playlist and music syncing on Atrix
TRICKorDEVICE
I tried MML software and it looked like it had promise, but more than half of my songs didn't transfer.
What are the best alternatives for iTunes syncing?
Doubletwist looked good but the app on my phone won't or doesn't seem to be able to see the sd card.
Thanks
Personally, while it still isn't perfect, I use Doubletwist with a 32gb card to sync my music from my mac, but I use other music players to go about playing the music. I'm not a fan of the Doubletwist player on android.
So far, my favorite is probably MIUI Music (a modded music app).
Also good:
Honeycomb music player (buggy, but works)
Motorola Connected Music Player (Stable, quick, lacks a few features)
Mixzing (Good EQ)
PowerAmp (One of the popular ones with a great EQ, but I'm not a big fan of it at all)
On MML, I selected a destination with no music for my (pc) music library (like the desktop). Then went to Settings, select Linking, and select Link to iTunes. Then, I went to Sync, then Sync Settings, and I de-selected both syncing options. Then on the left panel of MML expand iTunes playlists (should see all your itunes playlist). I then created new empty playlists on my Atrix (sd card) with the same names, under music not itunes. Then just drag the itunes playlist from pc to the same playlist you created on your device. It should transfer all the songs from your pc itunes playlist to the new playlist you created, which also happens to be the same name. No need to sync.
