I use Opera Mobile rather than Mini but that too had no option to exit until I enabled the exit button in the options. It tends to remember the page I was on if I exit that way (but not always).I'm using Opera Mini and can't find a way of exiting it. I have to back out through all my screens. Is ther a way to exit cleanly please?
The Menu button. The one to the left of the home button which does the Apps list on long press. OK, so it's not a physical button but I don't know another name for it.@bodestone
Holding up the menu button brings up the recent apps list not the search bar.
@bodestone
None of the buttons brings out the search bar. Are you using international note or lte ?
I downloaded " turn off the lights".(the one by protoport)....I installed it on my home screen. Now, I set my screen time to as high as I want it (10-30 min for me). So, the phone doesn't keep shutting off when I'm looking at it. All I do is touch the button "on the home screen" (I actually put it on all my home screens) and the screen turns off.
Hi. I downloaded it and like you, placed the icon on my home screen. I enabled it then pressed the activate button. Pressing on the home screen icon only brings me back to its enable/disable menu. Am I missing something? There are no other options available on the program.
Help please... Thanks.
I had the same problem on my phone and on someone elses. Here is the solution that worked for me. When you go to your menu/add+/shortcuts/turn off the lights...........then put 4-5-6 of the icons on you screen..then tap one at a time and see if one works as it should. If none work then put on a few more till u find one that does.....remember which one it was and use that......let me know if that works. It worked for me
Got lucky I guess.I discovered if you stomp on it real hard with a heavy boot on your foot you can use the glass shards to cut things. Clever little undocumented feature there.![]()
