xRoadkillx913x
So last night I tried to create a new theme. Created it using UOT Kitchen and uploaded, entered recovery and all I did was delete all my apps numbers and widgets
. So today since I got off work I have been hellbent on trying to figure out how to finish what I have started. I have tried the Sense Rom and CM7 Rom, and nothing. First if you can verify I have at least done this right.
I downloaded the zip, unzipped, transferred to root of sd card, through terminal emulator tried to flash the image, and it tells me that img cant be found. even though I addressed it properly.
I have watched countless videos, read articles, and screwed with my phone to try and figure this out. But I have overwritten the framework folder several times. changed all kinds of crap, and not sure if i should go back to a fresh 2.2 to start over. Also do i need to be 2.2 or 2.2.1, or does it even matter.
Please help
Corey
. So today since I got off work I have been hellbent on trying to figure out how to finish what I have started. I have tried the Sense Rom and CM7 Rom, and nothing. First if you can verify I have at least done this right. I downloaded the zip, unzipped, transferred to root of sd card, through terminal emulator tried to flash the image, and it tells me that img cant be found. even though I addressed it properly.
Please help
Corey
