J Kay's lock screen
GalaxyS2
I'm having trouble getting the lock screen to do anything but unlock. I have held the button options and selected images etc but they don't do what I want them to do.
What am I doing wrong?
Well they're all supposed to unlock. After which they go to the program. So for top left shortcut you make sure it's on JKay AOSP Deluxe then go into the top left shortcut selection and select a program (eg Gmail). The make sure you've selected 'Show when secure'. Now when you lock and swipe over Gmail you'll have to unlock and then Gmail will come up.
Unless you're running a custom theme (eg Revolution Super) and haven't installed jkay's stock samsung theme I don't see what's going wrong.
I was running Revolution Super, so changed to jkays stock and it still didn't work.
I would try reverting your theme back to stock, uninstall+reinstall jkay deluxe settings, then reinstall a jkay theme
I had Rev Super on and installed the following all at the same time:
Theme Restore Package V1
Samsung Stock Theme
Jkay Deluxe Settings V11
