Accessories Jabra SP700 bluetooth handsfree
shedboy79
Member
thinking about buying the above but have a few questions
as well as music and phone calls through my radio will it project the satnav
speech too ?
will i need a separate car phone charger ?
TIA
[LEFT said:
sudkcoce
[/LEFT];1499672]My advice to you is: get the Sony
Ericsson
MW600!
You won't be sorry ;-)
thanks for that, does it have the same options? like when you receive a call or sat nav speaks, does this cut in if your listing through the fm transmitter
I have got a Jabra SP700 and yes it does. It uses the same cable as the desire. to be honest i never bother with the FM transmitter but it works well. Battery seems to last forever with my limited use.
PS I am pleased with it !
Just to clarify, does the sat nav voice transmit via the blutooth unit also (and subsequently the car stereo)-or would I need to continue with the stock low volume speaker on the phone itself?
