Darbley77
Hope this helps some of you guys that have this.
On Mytalk, on the Jawbone site, they just added A2DP software that can be downloaded to replace the voice dial app.
"A2DP allows you to listen to music and podcasts, or even hear turn-by-turn directions through your Jawbone ICON. "
"A2DP lets you use your Jawbone ICON to listen to music, podcasts, turn-by-turn navigation and other audio. You can listen to your favorite song, and next switch seamlessly to answer an incoming call.
Note: Your phone must support A2DP. This current version of A2DP is optimized for the following phones:
To get A2DP working on your phone, you will need to remove your Jawbone ICON from your Bluetooth settings, then re-pair."
- iPhone 3G and 3GS
- Blackberry Bold, Curve, and Tour
- Motorola Droid
- Google Nexus One
- Palm Pre and Pixi
- Samsung Impression and Solstice
- LG enVTouch and enV3
