Root Jegar ROM Help (won't connect to PC)
SonicBoots
So I installed Jegar ROM the other day, and today I noticed that I can't mount the SD or phone storage on my comp. This may be really obvious to some of you, but I'm sort of a n00b at this. Is there a way to fix this, or can you not connect phone/SD storage as a disk drive when rooted with certain ROM installed? Or does it have to do with clockworkmod being on there?
happens on pretty much all his roms. go into menu>settings>connect to pc and uncheck the ask me box. when you plug it in, all you have to do is drag the notification bar down and you'll be able to change the mount option.
