Jelly Bean 4.2.1
steevo1
Member
Just got the Jelly Bean 4.2.1 ota update. I hope this fixes the bluetooth problem (losing connectivity frequently) that I have been having. Anyone else having bluetooth issues?
Woke up to find the update already downloaded and ready to be installed. I never had any blue tooth issues so can't comment on that but it does fix the so called "december bug" which meant that you couldn't add events to contacts for the month of December. Hasn't fixed that awful lag in camera when transitioning from portrait to landscape and vice versa so a bit disappointed...
Not everyone has lag in the camera, or any of the issues others have posted, other than the December bug. I did a clean install of 4.2 wiping everything, including system. I have no lag or any issues.
I dont have lag when opening up the camera app. or anything like other people. Only when transitioning from portrait to landscape in camera mode. Your saying you have absolutely no lag at all? I actually find it kind of stupid how android freezes the whole frame and then decides it will rotate the whole screen. Couldn't it just rotate the icons and keep the rest of the screen going...
Did this fix the vibrate on every email issue?
No OTA for me yet. :(
I never had any of the other issues anyone reported or they were subtle.
The vibrate on every email is really annoying. tho.
Yeah, I've been having bluetooth issues, but I didn't figure they were caused by the GN to be honest. Nice thought though...but whether I"m using headphones to listen/talk to mom or to listen to DJ Beauty thro out some Kazamtip electronic mixes, I just am always loosing bt connectivity.
I've yet to figure out how to get around it. I've got some Motorola s9 HD bt headphones which I've had--and cursed at--for about a year now, but I just figure bluetooth can't hop over my fat head easily and it's just going to loose noise once in a while...
I'll check right now, see if there's any difference that I can notice...best wishes :)
