Help Jellybean- car mode enabled bug
I updated to 4.1.2 using odin and ever since on the top left screen a car mode enable logo keeps popping up and then disapearing then popping up again. Does anyone know what this is and how i can fix it btw it is draining my battery
Just check that driving mode is not enabled
Settings
Language and Input
Text to speech output
Driving Mode
It is switched off
Hello
This could also be down to dirt in the USB port, i would suggest checking that out and trying to clean it, if that is not the reason then look at reflashing the firmware to see if that cures it.
Can you also let us know where you are located and which firmware upgrade you used
