Help JI6 Charge Complete
lexluthor
Android Expert
Since JI6 I've been getting an audible notification tone when the phone is done charging. Any way to turn that off? I don't get the point of it. What if I plug it in before I go to bed. I don't want to hear a tone 2 hours later. I sure hope there is an easy way to turn it off.
It happens on the Galaxy S as well. Annoying feature. It does serve a purpose I suppose.
And no, there doesn't seem to be a way to turn it off.
This is not good as it uses the notification tone you have chosen. Mine is Yoda saying "you have a message from the dark side"
There must be a way through root to shut this off.
Surprised not more talk about this. What kind of idiotic decision was it to make the thing have an audible tone when charging is complete with no way to turn it off.
And please don't chime in with, well just turn the ringer volume down when you go to bed or something like that. That's not a real solution.
I'll root it and then use root explorer to remove the association to beep when fully charged
Darn. And I was going to suggest you stick a marshmallow in the speaker before you go to bed.
It's probably possible to remove the file, or possibly replace it with a file with no sound as simply removing it may screw up a file association, but I have no idea where that file is. I'm not running the official JI6.
This went on for a while with the Omnia win6 untill the offending line in the registry was found.
And what's even worse is that the screen turns on (or in my case, when using Alarm Plus) takes the dim screen and bumps it up to full brightness! Wtf?!?
So, as it stands, the only solution is marshmallow in the speaker and smeared all over the screen?
