eklipze
Hey guys
Originally this was posted in the Velocity ROM thread but I'm sure most Ally ROMs will be able to benefit from these fixes:
The following will enable JIT and tweak your windowsmgr to allow for smoother scrolling.
Using ADB pull your build.prop:
abd pull /system/build.prop
add this line to the end of the file:
windowsmgr.max_events_per_sec=60
This will enable smoother scrolling.
Next, find the following line to enable jit:
#dalvik.vm.execution-mode=int:jit
and uncomment it by removing the # before it
Save the file and push back to /system/build.prop
reboot and your phone should be a little more responsive
I was having some permission denied errors when pushing the build.prop back via adb, so here's what i did:
(this part is optional, if your phone pushes the build.prop fine, then don't worry about this)
adb shell
su
mount -t rfs -o remount,rw /dev/stl5 /system
cd sdcard
busybox cp -R build.prop /system
mount -t rfs -o remount,ro /dev/stl5 /system
sync
reboot
**to those having trouble w/ the busybox command, make sure the build.prop is in the sd card, the sd card is not mounted in the computer, and you are in the adb shell of the phone
also, make sure you are cd into /sdcard/ and can see build.prop in the root of your sdcard with ls
then try to
alternatively if that doesnt work maybe try adb push build.prop /system/build.prop
Tested on Velocity 0.1.1 but may work with other ROMs.
adb shell
su
cd sdcard
sync
reboot
then try to
