Jkay Deluxe Settings Missed Event Icon?
Where can I find the event icons and missed event icons for jkay deluxe settings ics, I'm trying to change the icons for my go sms pro to the same for normal messenger.
Thank you
I can't find them searching via root which you have to do, you can't set the ics icons as a go sms as default ones, you have to search for them ;(
I need to find these icons to change them with default go sms icons thank you.
found a away
I'm creating an icon pack at the moment... with icons for all the most used apps.... like the XDA app
But until then... if you do a backup in the Deluxe Settings then the icons will be put on your SD card... look in JKayDeluxeSettings/backup
