JKay ICS themes
ironass
Extreme Android User
Don't get too excited! This is only the changelog for JKay's anticipated ICS themes release. ;)
"Status: Working on ICS version! (Release date: When it is ready!)"
Changelog
"ICS version will add:
* No need to reboot to change any settings anymore!
* Two more lockscreens (ICS and Rotary)
* Customize autobrightness
* Long press Back key to kill foreground application (won't kill launcher nor certain system apps like the phone app! With customizable timeout!)
* Double tap to unlock on JKay AOSP Deluxe lockscreen
* Keep Music/Radio Widget on lockscreen (no collapse) toggle
* 6 bars for GSM signal
* Added 'Do not disturb' quick settings button (the notification toggle from tablets)
* toggle for showing roaming icon
* toggle for showing asu level
* When hidding carrier label panel the date will be shown on the drag bar!
* Added a toggle to use custom date format
* Added a toggle to see Next Alarm Info on drag bar
* Added a 'Play USB connect sound' toggle
[Theme/Mod/Apk] XWLA4 - JKay Deluxe v13.6.4 - How the SGS2 should be! 2012-02-20 - xda-developers
For JKay Gingerbread themes, see here:-
http://androidforums.com/galaxy-s2-international-all-things-root/492764-jkay-13-6-2-now-out.html
JKay has just given an update over on xda.
I'm still working on the SystemUI of JKay Deluxe for ICS. Because so much has changed in code since GB I have decided to rewrite all my mod for the SystemUI. It will be good!!
Progress since last update:
* Redesigned Samsungs WiFi icons as I did not like the ICS look from Samsung!
* Added a 'Show Wifi In/out arrows' toggle
* Added a 'Append AM/PM to clock' toggle (to change '11:00 AM' to just '11:00')
* Added a 'Add leading zero to hour' toggle (to change '09:00' to '9:00')
* Added a 'Add day to clock' toggle (to change '9:00' to 'Sun 9:00'
* Added a 'Show bluetooth icon' toggle (to be able to hide the icon)
* Changed the implementation of battery level text (now with %)
* Changed the connection icons to be semi transparent
There's more information and some screenshots in these posts:-
xda-developers - View Single Post - [Theme/Mod/Apk] XWLA4 - JKay Deluxe v13.6.4 - How the SGS2 should be! 2012-02-20
JKay has released a little teaser as to his forthcoming ICS release over on xda forums, here.
Since I am given to understand that CheckROM v7 is being held back until the release of JKays themes and DeLuxe Settings, it's good news that he's cracking on with it and, judging by the screenie's below, it 's a cracker! :thumbup:
Sorry... I have been busy creating the JKay ICS Deluxe lockscreen..
It will support 15 shortcut actions! Here is how it works:
Press the lock handle and circle 1 will show with 5 icons.
Move the handle down left and circle 2 will show up with 5 other icons.
If you instead move the handle down right then circle 3 will show with another set of icons!
This way you can get to any of the 15 actions with a fast gesture move. See screenshots...
Circle 1 shown
picture.php
Circle 2 shows up:
picture.php
And circle 3:
picture.php
I will create an icon pack with a set of nice white application icons too!
Before anyone asks... It'll be released when it's ready! :dontknow:
and CRR have been waiting for this !!!!!!!!!
we`ve now got roms that can be tablets, rom control options, dpi per app etc etc etc and this is what jkay comes up with.
so glad i jumped off the CRR bandwagon a long time ago
So it's a modified honeycomb lockscreen with more options. Unsure why you'd need 15 shortcuts on the lockscreen. I personally never use that feature. Looking forward to what jkay really has in store for us.
I think I've mentioned before that it's not just the CRR team that will have jkay, it's everyone. So they'll all be the same jkay-wise, it's what additional features are provided that integrate well with jkay, and stability of course, that will set a rom apart from the others.
JKay has confirmed he will be releasing Deluxe Settings ICS "this month"
it will be for xxlps, xwlp7, xwlp8 and xwlp9 odexed and deodexed.
Looks like its going to coincide with the predicted CheckROM release date of 1st week in June.
Also added a new feature:
* Double tap Deluxe lockscreens to launch latest missed event
If enabled then when you receive a notification, you can see it on the ICS Deluxe lockscreen. Then if you Double tap the lockscreen the intent for this new notification will be launched. And this works for any application.
* long press home button on lockscreen to toggle flashlight' feature. In a later release more actions for long press will be added
