I must be doing something wrong here.
I'm trying to install JL4 from this thread
[ROM] JL4, build date 2010.12.17 - xda-developers
I have Odin 3 1.70.
I have the JL4 .tar file.
Samsung drivers are installed.
I take out the battery, then put it back in, then hold vol+/vol- and hit power and I'm in system recovery screen.
The last entry on the phone says installing muti-CSC.
I then connect the phone to the PC and it recognizes something on Com3. I then load the tar file in the pda section of ODIN. I'm not loading the PIT file.
When I click start, odin says file analysis, then setupconnection, then nothing else happens after that.
I don't need the .pit file, right? If I use the .pit file, does that erase the programs and data that I had stored on the phone?
Help?
I have Odin 3 1.70.
Help?
