Help .jnlp help
stetilley
Android Version: fully up to date
Network: 3
Taskiller Used?: yes, advancedtaskkiller free
Issue: hi guys. Just a query really. I've looked around a bit and the answer seems to be no.
Basically, my university has wireless, but you need to log in to use it. I guess the login is a java applet, as when i try to do it on my phone it just downloads a .jnlp file and says there is no app that can open it. The page i come from says java has to be installed.
I have java enabled in my browser but no joy.
Any ideas?
Thanks in advance
Steve
It's working on the assumption your device is a Windows device to install the browser plungin required. Windows applications cannot be installed on a non Windows device.
It's odd, I can log in at work fine but your place are using something that is maybe cheaper.
There's nothing you can do.
