Help Jorte not syncing with Google
debsto
I have been using Jorte calendar for over a year with no problem. Recently, events that I create on my Jorte calendar do not sync up to my Google calendar. Events created on my Google calendar do, however, sync down to Jorte on my phone. I have not changed any settings and, in fact, have looked at all the settings that would be pertinent and they seem to be correct. Has anyone else had this problem recently? There is nothing on Jorte's website to indicate this being a known problem with a recent update.
I've had issues like this from time to time. Generally solved it by deleting my phone's calendar data so it would rebuild from Google. If you have appointments on your phone (but not Google) that you don't want to have to recreate, there's an app called Calendar Repair that will backup/restore your local calendar.
Could you provide a list of the specific settings that you checked in Jorte, and how they're currently configured?
Have you changed any other settings that may have impacted this?
I just started having the same problem. Entries on Jorte don't sync to Google, but Google entries sync to Jorte. Started somewhere around the 20th of December. The only sync options I see are Jorte cloud, which I don't have. Do these problems have to do with that?
I have version 1.3.8, but my phone entries still do not update to google calender on laptop. They did before. How can I get them to start again?
Thanks,Bill
Have you tried deleting your Calendar Storage data to force a sync? This will delete anything you've saved on your phone but not on Google, though you can use an app called Calendar Repair to backup and restore your phone's data.
