Hi there,
Android Version: 2.2
Network: ??
Taskiller Used?: No
[Optional]Are You rooted & which Rom: No
Issue:
I'm a newbie Android smartphone user in love with my Desire
I've seen a few people on Android Forums recommend the Jorte calendar app, so I installed it and then I moved it to the SD card to save space on the internal storage. Then Jorte said that the widgets were not available, so I moved the app back to internal storage. Still no widgets available. Then I uninstalled Jorte, restarted phone, reinstalled, etc. several times - still no widgets available.
Any ideas what I can do about this?
EDIT: Problem solved - when I press the + on the homescreen, then I do get the choice of Jorte widgets even though the app says that widget settings are not available when app is moved to SD. Still puzzled about this, though....
Network: ??
Taskiller Used?: No
Issue:
