Help Juice Defender 3.1.0 issue
MarmiteX1
Hi,
I've just updated to a new version of Juice Defender but it doesnt seem to be working.
It keeps saying N/A when I check the amount that is trying to extend battery life by :(
In the previous version it would say x1.88.
Has anyone upgraded to the new version? If so do you have a similar issue to what I am experiencing?
Yeah I think this is because it's not had time to work out what it's doing for your battery yet. It takes a while to "learn", leave it a while and it should start giving you a reading eventually.
When is says NA it usually means it's disabled via the widget. Clicking on where it says NA will enable. Though perhaps the same is true when it doesn't have information, the data seemed to survive my upgrade so it didn't have to start recalculating from scratch.
