UPDATE: It seems that JuiceDefender doesn't work on CDMA phones with Android 2.1 - Motorola Droid and HTC Eris users, please be patient as I try to find a workaround, if possible - won't be easy, as I'm in EU.
Seems to work over here on my Evo. However, I have noticed that if you use the back button to leave the app, it seems to close it and then it doesn't work. I don't like that it doesn't let me know that. It also makes me do the setup like every damn time I open it if I use the back button to close it. Also, it seems to disable every time I enter it if I leave it using the home key, which is when it seems to work. I am not getting the notifications either.
Anyone else experiencing these things, or, am I just using this wrong or what?
