Gavisann
On the mobile data widget you get with JD, I noticed it said you can force data on, but when i click the widget I only have two options, off widget and on JD. When I place the app on my home screen, it says there is an option for widget ON, but I can't get it to work. I know I can go into the JD app and click disable, but it would be much quicker if I could do it through the widget. Any ideas why? I am using the free one.
