I had the same problem and found when not in a 4G area the phone will search for 4G and use a lot of power. I changed my phone to cmda 3G only and now good battery life.
I used Customize and then disabled "Mobile data" under the Settings tab. Have not had an issue since.
Hi. New android user here. I recently purchased a Samsung Droid Charge from Verizon. Love the phone and the android OS, but the battery life is pretty bad. I had read about juice defender and it sounded like something worth trying.
Installed JD on my Droid Charge and used the default options. The problem I'm having is when I unlock the phone and go to use anything that requires a network connection, I'm getting an error that no network connection exists. The 3G icon is not displayed in the task bar even though I have a good signal. Notification drop down show that mobile data is active.
I have also read through the thread on connection problems and quite a few people have been having connection issues with the Droid Charge, so I'm not sure if it's a phone issue, or a Juice Defender problem. I have had a couple times when in a low signal area I lost 3g and had to restart the phone to reestablish. FYI, I'm current not in a 4g area. We're getting 4g later this year.
Any thoughts?
Kevin
Has anyone had similar problems with this phone/software combo?
Just found this but am wondering if my trouble is the same. When I am at home my phone now uses my home wifi network. However when I leave home and try to use the browser, I get the message "network not available. Please check your network and try again". It is only the browser that does not work. Texting and phone calls work fine. Turning off JD fixes the problem. Is this the same issue as everyone in this thread describes?
For those users that "have no problem with battery" I'd like to know what you consider to be nominal battery life.
I'm getting about 10 hours like the OP, and it's hard to imagine that much variance between users. Are you guys using 4G? I've seen outrageous claims of 30+ hours on a single charge, and I am just going to have to call BS. That has to be with your phone just idling there, and possibly with networks turned off with no accounts syncing.
Keep in mind the 10 hrs is with extremely light usage, and with the screen set at the lowest setting or at 10% brightness.
The Droid Charge is an awesome phone, and 4G and SAMOLED+ are awesome--but that comes at the price of the battery.
I think people need to stop misleading potential buyers, because I walked into this thinking I could expect 20 hrs at least with light usage. It's not even close.
Please, no more battery usage quotes on 3G--or if you do, clearly specify that you are quoting 3G.
