Works great for me. When my screen is dark, all my radios are off and I use very little power.
So do you manually sync your email accounts etc?
So if I understand it correctly, JD turns off the radios while the phone is off, activating them periodically (every 5, 15, 30 mins etc) to pick up new data. Does all this turning on and off take a toll on the battery? I know people say constantly closing and opening apps can drain battery, so how is this different?
Task killers that close a system app that immediately reopens itself, which causes the task killer to kill it again it's next cycle, will drain battery.
Shutting off the radios for 15 minutes and then turning them back on will save. But turning on and off radios with no more than 5 minutes in between will probably cause more power draw than just leaving the radio on. But I have no actual numbers to support this. Just a rule of thumb that I follow.
I believe the JD Free version which I'm using is set automatically to update at fifteen minute intervals (actually looks like every 14 according to the log). Is there a way to change this in the free version or would I have to move to JD Plus? Do you think there is any battery saving advantage to moving the update to every 30 min?
