Thanks guys for help. But Now dumbest question...I have wifi at work and house...I use 3g data only when I go from work to home, which is like 1 hr in morning and one hr in evening. Also I have tweak to disable my data (which is off most of the time, so I mainly use wifi). therefore I got Ultimate Juice to save my battery drain. The settings showed above are mainly to save data and not battery.
I leave my wifi on whole day as I stream radio on my phone. I know that affects the battery a lot too, right? I have all syncs on manual. Just back ground data is on.
I am not getting more than 9 hrs of battery. I listen to preamp music player from like 2 hrs with no wifi and data on. I listen to radio on wifi for like 7 hrs. I check my tweetdeck, facebook and gmail freguently. Also frequent texting using Google voice. I read Kindle for like 30 mins everyday while on my way to work.
Is apporx 9 hrs of battery everyday with this use is normal or I should be concerned? I dont use task killer, and all the apps above goes into inactive as I go back after using them (using system Panel to check that).
I was happy with the battery performance till I saw other people getting more than 24 hrs of battery. This is my second phone. should I replace this one too?
9 Hrs of battery while streaming radio for 7 hrs? That's pretty stout if you ask me.
