Help juicedefender won't go online
saintdanbert
I'm running juicedefender with much success. Has anyone seen this behavior? Can anyone explain what is going wrong.
I have JD configured to prefer wifi over 3G. I enter a space with a load of wifi nets visible. Sadly, all of the nets are locked or otherwise not accessible. When I try to access the internet, my phone complains and will not activate a 3G connection even when 3G signal strength is good. I can access the net only after I take JD offline.
The symptom looks like: "JD sees all of this available wifi. One will surely work, so block 3G use."
Merci d'avance,
~~~ 0;-Dan
________
Android v2.1 on Captivate with AT&T
