just a few problems
i have a few problems with my eris and the search here isnt the best
sorry if these have been asked and answered before
1 the alarm wont ring when it should
2 when i hit the back button (when im on a web page) it takes me to the last time i tried to use a wifi spot ...ill be on facebook and i will hit the back button and instead of going back one page it takes me to a hotels page to access their wifi it doesnt happen every time but most of the time
3 most times i cant load a pic to facebook
i have stated using pixlepipe
ok thats a start
if anyone can help that would be cool
ok thats a start
1. Try just setting one alarm, turn vibrate off. The native alarm sucks, I like Koeler clock, it's an alarm and docking station.
2. Very weird. I don't use wifi, so haven't had this bug. Are you using the browser that came with the phone or a replacement? Are you running android 1.5, 2.1 leak, or 2.1 root? Knowing these might make it easier to help you.
3. I haven't tried loading a pic too facebook, maybe someone here has an idea.
How that was at least somewhat helpful!
i have tried the stock alarm and also better alarm both with vibrate off will not work i will try the one you suggested though
i am using the stock browser with 1.5 i guess
I always have issues uploading photos to facebook via wifi.. I always disconnect and do it over network.
1. alarm: for many people first using the fone, the alarm volume gets turned down somehow. yes, it is annoying/helpful that it is a separate toggle. If you don't mind the stock setup, I recommend a volume control app like VolumeSetting [cVolume] Free so that you can check individual volume toggles easily. just search cvolume in market
it also includes a very handy widget for 1click cycling Ring, Vibrate, Silent
1.also phil/nichole check that when you set an alarm sound, that you use the volume rocker to turn up the sound. It has to been under the screen when you select the alarm sound though. Also if its the weekend be sure you set your alarm to go off on saturday or sunday, by default most alarms are set for M-F.
2. trying going to manage applications and clear the cache to the browser.
3. try downgrading your pics to 3mp or 1mp see if that helps.
when u guys type do you guys get lag. I have used the iphone keyboard it is so much responsive.
is there a way to change the keyboard on the eris
