Ok, I have just a few questions about the X. Hopefully I'll have it before 9/7!
I think I heard there is no sound profiles on the X. Do you manually have to go in a turn all the sounds off or would something like switchpro have a setting that turns off all sounds but leaves on vibration?
With LPP is there settings to change the dock buttons or do you have to customize them yourself?
Hopefully I didn't miss a thread with this info and if I did then I apologize.
