Root just a little help to send me on way.
sudeki300
yesterday i rooted my desire but i have no interest in installing a custom rom. all i want to install is apps2sd or apps2sd +i have read many guides but most of them conflict each other.if i was to follow these steps what would be wiped from the phone.
  1. Using the optical trackpad select Wipe > Wipe data/factory reset
  2. After this has completed do Wipe > Wipe cache
  3. Again, once this has completed do Wipe > Wipe Dalvik-cache.
i understand that the sd card gets wiped and that is not a problem, i'm more worried what gets wiped from the phone memory (not worried about installed apps) also can i do the ext3/4 from the phone as i only have windows 7.thanks......................sudeki300
That basically wipes everything except the rooted rom you have on there. All your settings, apps and app data.
Since you're rooted, try a titanium back up first and you can restore stuff.
The bottom part. Its ext2 > 3 not 3>4 and you can do this on your phone. Try installing ROM manager to do it.
Can I just ask a quickie question here, too?
I'm in the same position - I have rooted the stock ROM and don't want to install a custom one, only to add apps2sd+ to the stock (rooted) ROM.
I have ROM Manager and I'm OK with the partitioning side of things, but could someone put up a really simple explanation of how to actually add the apps2sd+ functionality in this scenario?
Thanks.
All I can say is that I have tried a few times and failed every time. In the end, I went for MoDaCo 3.1 with A2SD+ installed on it.
