Im trying to take my phone back to stock. I restored from back up to erase Liberty. Now I want to make sure I do this right. How can I remove the super user app and are there anything else I need to do to make sure its back to the way I bought it? Thank you for your help.
Was your backup original stock? If so with phone off Hold down Home key and power button at the same time. Phone will boot into recovery. Press Search key then using the volume key toggle to wipe data / factory reset. Press the camera button to execute. After reboot skip logging in to google and you should be back to just as you got the phone.
