Hey,
I have just taken the plunge on buying a rip-off ipad from ebay after browsing the forums here and over at slatedroid.
From what I could make out, there is a number of 10 inch slates which are coming out now which are all basically the same, using the zenithink board. So I guessed that the 10.2" device that I bought would basically be a zenithink. However the ebay seller says this is essentially a large rockchip. But I can't find any info about a 10.2" rockchip tablet, just 7" models...
Here are the specs provided by the seller:
10.2" Rockchip Android Tablet Apad 1GHZ DUAL CORE PROCESSOR!!
CPU: RK2808 1GHZ Dual-Core - FASTEST PROCESSOR!!
Google Android OS 1.5
256MB DDR2 800mhz
Display: 10.2
256MB DDR2 800mhz
Display: 10.2
The rockchip at 1GHz seems impressive, but many stores list the CPU as the combination of the two cores. One is a ARM9 CPU and another is a DSP. But it would be nice if it really was a ARM9 CPU at 1GHz, so it might be worth checking out.
I expect it will arrive tomorrow now (which is annoying as I am out all day). But I will still post here once I get my hands on it!
