Accessories just bought a seidio extended battery 2600 mah and...
Needforspeed
I was wandering if there are any tips to calibrate the battery and if you own one please tell me how you like the battery and how long it has lasted you.Also I was wandering what should I do with the OEM battery that came with the phone like do I drain it first,and can I store it in a drawer after I do whatever I have to do to make sure It wont explode or anything as I would like to keep it if I need a backup.
Don't drain your backup battery. Charge it to 40-50% if you are going to store it away. It needs to be stored in a cool, dry place.
How to Store Batteries – Battery University
