chirantha7777
Ok just received a 2430mah Gold Battery from a Top Rated Ebay seller. The battery does feel heavier than the stock one... Charging the battery at the moment.
Here are my findings
1. The Battery length is shorter by around 1mm so the thing fell out the phone... used peaces of tape to lengthen the battery at the bottom...
2. The Battery is Fatter than the stock battery by around 2mm
3. The height (height when laying flat) is taller than the stock battery... by around 1.3mm
4. The Battery charged faster than the stock battery....
initial charge at delivery was 66%....
EDIT : Its charging slower than the stock now
its slooooooooooooooooooooooow
initial charge at delivery was 66%....EDIT : Its charging slower than the stock now
