S smroark Member Sep 21, 2010 #1 It wont do a factory reset It leaves all the data from the last person that owned it on there. Any solutions?
D dbrookes Newbie Sep 21, 2010 #2 Did you try: Settings -> SD card & phone storage settings -> Unmount SD card Settings -> SD card & phone storage settings -> Format SD card Factory Reset does not affect the SD card. --D.
S smroark Member Sep 21, 2010 #3 dbrookes said: Did you try: Settings -> SD card & phone storage settings -> Unmount SD card Settings -> SD card & phone storage settings -> Format SD card Factory Reset does not affect the SD card. --D. Click to expand... Im not talking about the SD Card. Im talking about the phone itself. I still have all of the previous owners contacts, etc...
S st3v Lurker Sep 21, 2010 #4 Factory Reset option 2 - Warning this will reset device back to original factory settings. Turn off the phone Press Power key + "x" (on the hardware keyboard) to power on the phone and bring up the recovery screen Press and hold Volume Up + Camera Key until recovery menu appears, release keys when it appears Using the Volume keys, select "Wipe data factory Reset", Press the center of 5-way navigation pad Using the Volume keys, select Yes -- delete all user data Press the center of 5-way navigation pad Using the Volume keys select Reboot system now Press the center of 5-way navigation pad
S smroark Member Sep 21, 2010 #5 That didnt work. I *just* fixed my phone lol I followed a couple of Tuts from other websites and fixed my Droid. Thx for the help tho!
