Root Just got my Epic; need help picking a ROM
Mo786
I just got my Epic a few days ago and noticed the horrible battery life. I was warned by the Sprint representatives, but I didn't think it would be this bad.
Anyways, after searching and looking around, I found out that the best solution is to root it and get rid of the all the bloatware that came pre-installed.
Now my question is, what ROM should I pick? I like the look of the device and most of the features. I just want most of these stupid pre-installed apps removed.
I still want the GPS and the TouchWiz drop down thing is pretty nice.
All I'm really looking for is longer battery life with the least amount of features removed. I need it to be stable as well of course.
So, any suggestions on what ROM would be good for me?
You don't have to flash a ROM right away. Root access alone will allow you to remove bloatware.<br>
<br>
<br>
<a href="http://forum.xda-developers.com/showthread.php?t=1061912" target="_blank">[ROM][ODIN][RFS/EXT4][NOCIQ] EC05 Stock Plus Updated 5/5/2011** - xda-developers</a> is my preference.
<br>
I see<br>
I see. So which ones should I remove? As in which ones are the most useless and biggest battery hogs?
Also, is there a way to tether without using a ROM?
Yes, you can tether with just root access. Use Juice Defender for better battery life. Set display brightness to auto.
I have not noticed better battery life by just flashing a rom.
ACS just came out with EE03 and it works great. i have been using it all day and have seen no problems at all with it. it is 2.3 gingerbread and it is alot faster than froyo 2.2
