Root Just installed CM7 and I have a question about it.
sega dude
Member
I have successfully installed CyanogenMod 7 on my triumph and so far i'm loving it! In the stock froyo rom, the led would turn red while charging and green when it finished charging. In CM7 it stays green even tho its not fully charged. This is a way I can change it back to the way it was before? This is the only thing I don't like about it.
well the reason it turns green is to indicate that it is almost dont charging and that the trick charge state has started
It turns green at 90% and slows the charge so you do not overcharge your battery (and cause bad things to happen). I thought this was the same behavior as on the stock ROM.
