link00seven
Hi all,
I successfully rooted with the guide on this site and used ROM Manager / Clockwork Recovery to flash CyanogenMod 6.1.1. So far so good there.
However, I tried installing the Adfree (listed in that guide) and got an error. Doing some more research I find that I cannot write to /system. When I rebooted and held POWER+VOL-DOWN I see in the bootloader that S-ON is still there. I thought if I would've made it this far...that it would show S-OFF.
At this point, how can I try to fix this? Do I need to try to re-root via Unrevoked? Should I go back to the NAND backup I made right after I was done rooting (I made it via ROM Manager immediately after the root was done, before flashing CyanogenMod).
Thanks for your help.
